HELP!
KILLVOX
When the pathy is a t normal idle rpm's the tac fluctuates up and then down and stalls. If i keep my foot on the gas pedal it stays running. but as soon as i let off, it stalls. Some one told me to replace the throttle body sencer so i did. wasnt the problem. I have a good flow of gas going to the engin so i dont think its the fuel pump. Please help if you can. thanks :sniff:
It probly wouldn't hurt to get some SeaFoam and add that to your gas and pour a little into your trottlebody... I used some on a 89 toyota pick that I'm driving and it made a world of difference. I was having an idling problem with that truck also. Now it's smooth as hell.
first thing i did was do a check on the ECU. and it gave me an error code 55 ( no malfunction).Thanks again for the tips. Im going to try all of them this week end. the problem is intermitant. its actually running good now. A little bit of black smoke did come from the exhuast when i first started it after it was sitting for about 9 hours. What is "LIMP" mode.
