nycxice13 Posted August 18, 2005 Share Posted August 18, 2005 Ok I have a 98 pathy a/t , problem is Im getting a vibration starting at 40 mph. It feels as if it is coming from the front because I can feel it in the steering wheel. Any guesses on what it could be? Tires are new and balanced Im going for an alignment this weekend. Link to comment Share on other sites More sharing options...
94extreme Posted August 18, 2005 Share Posted August 18, 2005 search the forums.. something similar was just discussed recently.. Link to comment Share on other sites More sharing options...
nycxice13 Posted August 18, 2005 Author Share Posted August 18, 2005 any idea of by who or the topic name? Link to comment Share on other sites More sharing options...
94extreme Posted August 18, 2005 Share Posted August 18, 2005 something about front end vibrations.. r50 too.. probably in that forum Link to comment Share on other sites More sharing options...
nycxice13 Posted August 18, 2005 Author Share Posted August 18, 2005 Thats while towing only, and he said its coming from the rear. I think Im dealing with a different kind of beast. Link to comment Share on other sites More sharing options...
94extreme Posted August 18, 2005 Share Posted August 18, 2005 sorry.. couldn't remember exactly.. good luck.. i don't know r50 well enough... keep trying.. there are a few here that know your car inside and out.. Link to comment Share on other sites More sharing options...
vengeful Posted August 18, 2005 Share Posted August 18, 2005 Front end vibration above 40mph? Wheel balance. Alignment CVs. Unless you're on the brakes when it happens, then warped rotor(s). Link to comment Share on other sites More sharing options...
nycxice13 Posted August 18, 2005 Author Share Posted August 18, 2005 im thinkin the cvs are shot, hard to replace? can I do it myself? Link to comment Share on other sites More sharing options...
vengeful Posted August 18, 2005 Share Posted August 18, 2005 I've done it many times, so I don't find it difficult, but then again, I've got the manual hubs, so they are super easy to remove. It takes me now about an hour per CV. My first one took nearly 4, and I was black from head to toe from grease. It's a messy job for sure. It IS something you CAN do yourself, but the job is not a fun one. Link to comment Share on other sites More sharing options...
nycxice13 Posted August 18, 2005 Author Share Posted August 18, 2005 Heck, I got like a quart of oil on me doing my first oil chnge, grease doesnt bother me. Ill give it a try. Link to comment Share on other sites More sharing options...
vengeful Posted August 18, 2005 Share Posted August 18, 2005 Do you have a service manual? If not...GET ONE. Link to comment Share on other sites More sharing options...
nycxice13 Posted August 18, 2005 Author Share Posted August 18, 2005 Yea, thats a deffinate thing Im picking up. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted August 18, 2005 Share Posted August 18, 2005 Front end vibration above 40mph? Wheel balance. Alignment CVs. Unless you're on the brakes when it happens, then warped rotor(s). Wheel balance. The cvs are not moving (unless he is in 4wd). Link to comment Share on other sites More sharing options...
nycxice13 Posted August 18, 2005 Author Share Posted August 18, 2005 they are brand new and balanced Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 19, 2005 Share Posted August 19, 2005 The cvs are not moving (unless he is in 4wd). They are if he has a 96-up Pathfinder. They have fully-locked drive flanges instead of locking hubs, so the CV's always spin, regardless of transfer case position... That's why people replace them with Warn hubs, so the CV's can sit still and not eat so much power from the drivetrain by just always moving. Link to comment Share on other sites More sharing options...
Ramithepimp77 Posted August 19, 2005 Share Posted August 19, 2005 I had some vibrations from the front in my old car. My tire was REALLY low on air but the other one was fine. Filled up the low tire, drove it, and no more vibrations. Prolly isnt that though HAHA Rami Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted August 19, 2005 Share Posted August 19, 2005 The cvs are not moving (unless he is in 4wd). They are if he has a 96-up Pathfinder. They have fully-locked drive flanges instead of locking hubs, so the CV's always spin, regardless of transfer case position... That's why people replace them with Warn hubs, so the CV's can sit still and not eat so much power from the drivetrain by just always moving. I didn't see the year. Sorry. Link to comment Share on other sites More sharing options...
vengeful Posted August 19, 2005 Share Posted August 19, 2005 they are brand new and balanced Are you using OEM Nissan wheels? If so, the balance may still be off, if the shop did not use a Hunter 9700 (Road Force) balancing machine, or if they did, they may not have used the adapter plate. Try to find a shop that uses the Hunter 9700 and have them rebalance the wheels using the adapter plate. Also, have your alignment checked. Link to comment Share on other sites More sharing options...
nycxice13 Posted August 20, 2005 Author Share Posted August 20, 2005 Yep they are the nissan oem, I'll try to find a hop eith that machine dunno how easy it will be. Link to comment Share on other sites More sharing options...
