SteeevO Posted August 7, 2005 Share Posted August 7, 2005 recently i realized that on the bottom of the doors there are what look like drain/vent holes... i was thinking if i were to cross a stream water would get inside the door and wet my aftermarket speakers and the motor for the electric windows...would it be safe to plug these holes and if so what do u think would be the best way to plug them? thnx Link to comment Share on other sites More sharing options...
Slick Posted August 7, 2005 Share Posted August 7, 2005 Well.. if you plan on going into water that deep... your first concern should be the ECU which is located under your passenger seat.. then install a snorkel if going really deep..... what year is your Pathy? I assume it is the same as mine as you posted in 90-95 WD21's... Link to comment Share on other sites More sharing options...
Precise1 Posted August 7, 2005 Share Posted August 7, 2005 I believe those holes are there to allow any water that gets past your window seals to drain out. Have you looked up in them to see if there is a screw ? Hmm, now I'm curious. I'll peek tomorrow, but I pretty sure about the first answer. B Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 7, 2005 Share Posted August 7, 2005 I wouldn't plug those drain holes if I were you, unless you want your door to slosh when you shut it after it rains...and then rust from the inside out later... Link to comment Share on other sites More sharing options...
SteeevO Posted August 7, 2005 Author Share Posted August 7, 2005 i did not see a screw up there. but even if there was a temporary way to plug them just for when i go out on these adventures it would be nice. i do realize they are drain holes but...honestly how much water actually gets inside??...i don't think much ...maybe a little damp but i think it would just be able to evaporate through the other vents higher in the side of the door near the latch and also the speaker grill is right next to a large hole in the door panel alowing for evaporation....i think...just a thought ha ..i'm just too worried about my frigg'n speakers Link to comment Share on other sites More sharing options...
94extreme Posted August 7, 2005 Share Posted August 7, 2005 we all have the speakers in the same spot and nobody here has had a problem with flooding them during water crossing.. you want rust? plug'em up... Link to comment Share on other sites More sharing options...
SteeevO Posted August 7, 2005 Author Share Posted August 7, 2005 alright alright u win.... Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted August 7, 2005 Share Posted August 7, 2005 I would like to add that if your car doesn't take in water it will float. The holes do serve purposes. Link to comment Share on other sites More sharing options...
SteeevO Posted August 7, 2005 Author Share Posted August 7, 2005 lol....yeah it thought about that too... Link to comment Share on other sites More sharing options...
derogate Posted August 7, 2005 Share Posted August 7, 2005 my friend has submerged his 65 watt JBL 6x9's in muddy water on numerouse occasions and they still continue to function till this day. I think you have to be more worried about shorting an amp, or your deck, than the speakers. At least from my opinion. Link to comment Share on other sites More sharing options...
SteeevO Posted August 7, 2005 Author Share Posted August 7, 2005 i'll just have to remember to turn off the deck when i take my pathy scuba diving....lol Link to comment Share on other sites More sharing options...
Slick Posted August 9, 2005 Share Posted August 9, 2005 You should turn your stereo off while wheeling anyway.. in case someone tries to yell a warning to you or your motor malfunctions.. you can hear what's going on... Link to comment Share on other sites More sharing options...
SteeevO Posted August 9, 2005 Author Share Posted August 9, 2005 yeah i actually never have it one when i'm wheel'n i listen for everything when i'm out there Link to comment Share on other sites More sharing options...
