MATTY Posted August 3, 2005 Share Posted August 3, 2005 hi guys have been looking cant find any info but i would like to put 16 x 8 265/75/16 patrol wheels on my pathy can it be done? at the moment i have 15 x 7 265/75/15 are they mutch taller? will they rub? i have a 2 inch lift everything else is stock will i need spacers underneath the wheels theyre both 6 stud so theyll bolt on no worries thanks guys Link to comment Share on other sites More sharing options...
DJ Dank Posted August 3, 2005 Share Posted August 3, 2005 hi guys have been looking cant find any info but i would like to put 16 x 8 265/75/16 patrol wheels on my pathy can it be done? at the moment i have 15 x 7 265/75/15 are they mutch taller? will they rub? i have a 2 inch lift everything else is stock will i need spacers underneath the wheels theyre both 6 stud so theyll bolt on no worries thanks guys 265/75/15 is 30.6 inches in diameter. If you go to 265/75/16, you're jumping up to 31.6. You'll gain an inch. With a 2 inch lift, you'll be fine. Link to comment Share on other sites More sharing options...
