Wiring From Engine Bay To Cab
I found a removable, oblong shaped cover just beside the brake master cylinder on mine ('95 RHdrive) that is over a good sized hole right through the firewall. I used that to run the wires for the Auto lockup bypass that Dieselboy posted in Garage awhile back.
Cheers
Al
i punched another hole in that huge grommet that holds most of the rest of the wiring... its located up on the passenger's side of the firewall, jam your new wires down in there and they come out under the glove box.
