Ramithepimp77 Posted June 22, 2005 Share Posted June 22, 2005 So far two times I have noticed my back passenger wheel smoking and smelling STRONGLY like brakes. I think it might be locking up or not dis-engaging or something. Anyone ever have this prob on their Pathy? Any suggestions? Thanks Rami Link to comment Share on other sites More sharing options...
Simon Posted June 22, 2005 Share Posted June 22, 2005 Rami, You probably have a shoe or pad (depending on whether you have rear discs or drum) sticking, most likely caused either by a sticking caliper if you have discs, or a stuck spring, or malfunctioning wheel cylinder or auto-adjuster in the drum. Take it apart and have a look to see if everything's moving freely. Link to comment Share on other sites More sharing options...
Ramithepimp77 Posted June 22, 2005 Author Share Posted June 22, 2005 OOPSY :o I forgot to mention I have rear disc brakes. I resently had them replaced BY A FRIEND not a shop. Sorry. I should have remembered to add that in the original post. Rami Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 22, 2005 Share Posted June 22, 2005 Sometimes brand-new brakes will get too hot and smell like that, but if they were JUST replaced, they could be just bedding in and not have anything wrong with them. Or the e-brake adjuster could need some touching-up. There is a small drum brake inside the rear discs that makes up your e-brakes. Link to comment Share on other sites More sharing options...
nige Posted June 22, 2005 Share Posted June 22, 2005 o-o-o-o maybe sticky slide pins? Link to comment Share on other sites More sharing options...
firstpathy Posted June 24, 2005 Share Posted June 24, 2005 im going with the seized up e-brake cable Link to comment Share on other sites More sharing options...
Ramithepimp77 Posted July 8, 2005 Author Share Posted July 8, 2005 It locked up AGAIN yesterday. 2morrow I have a day off so Ill take it apart and let you guys know what I see. Rami Link to comment Share on other sites More sharing options...
