I need some one to look
MaritimeMan
1991, SE 4WD
I need some one to go and take a gander at the passenger side of the xfer case. I have two sensors, each with two wires comming out of them, for a grand total of 4 harnesses. I have two on the incomming wiring harness, and I need to know how to connect them. The wires off the main harness are yellow and black, the yellow being a female harn, and the black male. Thanks, shout if you need more description.
Allright, I went out and crawled in the gravel for ya...bastard. You owe me.
The yellow wire goes to the black/brown wire on the top sensor, and the black/brown wire from your incoming harness goes to the bottom sensor. The two sensors tie together via the black wires, evidently.
You're welcome.
