front and rear calipers and rotors
Any suggestions for quality brake calipers/rotors? Brembo, akebono, and some others don't carry ones that fit.
I'd like to get good ones, probably have to buy in units.
if you cared enough to try, the caliber bolt spacing measures the same if I remember correctly from 96-99 r50 they run 17MM bolt calibers and the 00-04 use the larger 19MM and larger rotors
