Planning out Lift Kit Parts
csprinkle
Hello all,
I've gathered some decent experience in terms of mechanics after working on my car a bit but I still am quite uneducated in how the suspension is set up. I'm trying to draw up a plan for all the parts necessary for my lift and wanted some feedback so I don't miss anything! I've went through the forums a bit to try and see what others are running but again, not too sure what I'm getting myself into here. All I know is that if I'm going to mess with my suspension, I want to do it right and replace coils/struts/shocks rather than just try to get by with a spacer lift. Spacers after the OME coils settle would be fine though. Hopefully this doesn't set me back a fortune.
My understanding is that the "standard" or a popular suspension set up is as follows:
Front: Old Man Emu (OME) HD coil springs alongside KYB struts
Rear: Land Rover MD (9447) or HD (9449) alongside 2” Bilstein shocks
What else am I missing here in terms of equipment or modifications to my Pathfinder? Would I have to extend my brake lines, etc.
As for how to obtain the equipment, I'm also a bit lost. I know SFCreations is no longer producing new lift equipment so that's out of the question, but I know 4x4parts.com is another common source for suspension parts.
If you believe there is a better website or even a better part to use instead, please let me know! I am open to any and all feedback/suggestions. I know there's a lot to digest in this post, so hopefully one of you is willing to sit down and nerd out for me here. Thank you!
Edited by csprinkle
added KYB strut info (models, links, price)
I'm selling Bilstein Shocks 5125 33-185552, AC rear coilsprings
(the 2inch lift ones assuming they are LR coils)
Used them for less than a year. Got different set up after doing sfd.
They are in good shape, I can ship to you. I'm only asking 100$ canadian for the shocks and coilsprings.
You will just need to buy front spacers or front coilsprings, that is all you need for 2 inch lift, won't need extended brake lines.
Hey, thanks for the reply. I may be interested in your equipment as long as someone can confirm these would also work for an 02. Not familiar with the differences between model years.
Wasn’t exactly going for AC coils but I would consider.
Edited by csprinkle
accidentally hit send
If you want the parts and you will pay for the shipping I will gift them to you. On one condition you post before and after pictures.
You will just need to buy yourself front coilsprings or spacers granting your struts are still good.
The whole install should be quick
Edited by BCangler99
Wow, speechless over here. I’ve literally been daydreaming about a lift for weeks now but I’m just a college kid with a very tight budget 😅 That would mean the world to me if you’re really willing to gift me the parts. And yes, when I get around to lifting it, I am definitely posting pictures. Check your inbox for a message
 Unless you pick them up yourself, shipping will be very expensive. You will also need to consider lifting a vehicle puts added stress on some components, so be sure to budget for repairs.
Looking at rear AC 2” lift coils, Bilstein 5125 shocks, and a missing link courtesy of@BCangler99.
Probably going to run front AC 2” coil springs and front KYB 335015/335016 excel-g struts
4x4parts.com kept telling me I should get the camber alignment kit ($30/e) as well as a new strut tower mount ($50/e) for each wheel, are those required or just random crap they’re trying to upsell me on..
Any other required equipment while i’m on a shopping spree? I’ll definitely save some cash on the side for necessary repairs that come with lifting a vehicle
The front AC coilsprings are closer to 2", but get whatevers in your budget.
You'll want to check your struts out before buying new ones. If they're old you can just get new ones.
You can get your camber bolts from most local shops, they aren't uncommon.
When you go in for an alligment they can do the camber bolts if you can't do it.
There's a new tariff today though canada post shipping to the states.
I don’t mind paying the tariff, just let me know what their estimate is. I wouldn’t want to shell out more than $150 usd for shipping..
  • 1 month later...
Tyler's videos helped a lot when I was deciding what I wanted to do when I still had very limited knowledge of these rigs.
If you did a subframe drop as opposed to a coil lift in the front you wouldn't have to use camber bolts as you can fix the camber in the spacers. How ever, I would suggest doing the AC and LR route. It feels great as a daily and being a college student you should have minimal issues (sight bumper rub when full lock and CV boots like to tear).
