1999 wheel hub repleacement
corey99
Can anyone tell me if the 4wd wheel hub will work on a 2wd. Had a mechanic install front wheel bearing and he did not do it correctly (I know I should have done it myself) now the hub is wallered out and needs to be replaced but can't find any replacements for 2wd any where. If anybody knows where to get the 2wd hub replacement that would be fantastic tia.
I've never worked with the 2WD parts, but I had a look at the parts diagrams on NissanPartsDeal, hoping to see the same part number between them. Instead I found six of them. 4WD shows 40202-0W094, 40202-0W091, and 40202-0W092. 2WD shows 40202-1W091, 40202-1W092, and 40202-1W094.
Naturally I have no idea what's different between those six part numbers, or if it's significant enough to stop one from fitting the other.
If you can't find a used one, NPD does have one of the 2WD part numbers still available. Punch in your info and see if they reckon it'll fit.
