Pathfinder rough idle/surging
savePF
MmI have a 93' Pathfinder
V6 automatic. It has a rough idle and engine surge.
It usually starts right up, idles up to 900 rpm, then drops to 4-600 and idles rough.
It also has a slight stumble in park during acceleration. Check engine light on.
Here is what I have done so far.
REPLACED-
Burned out ECU (no codes)
Air filter
Plugs
Distributor cap
Rotor
EGR and hose
PCV valve
Coolant temp sensor
Battery
CLEANED-
MAF
Throttle body(front and back)
Entire engine bay
CHECKED-
O2 sensor by unplugging while running
All vacuum hoses
And replaced any worn, cracked.
Did the carb cleaner vac hose spray test on all visible (including the slightly hidden FPR) vacuum hoses.
The only thing I can think of is the IAC?
Please help!
Thanks
REPLACED-
Air filter
Plugs
Distributor cap
Rotor
EGR and hose
PCV valve
Coolant temp sensor
Battery
CLEANED-
MAF
Entire engine bay
CHECKED-
All vacuum hoses
Please help!
Thanks
I see this has been read a little. If you can please post whatever you have.
Thank you
Try a good IAC, then maybe do a smoke test for vacuum leaks.
Check Grounds and elec connectors.
All that being good I'd do a compression and leak down test to rule out rings or valves.
Edited by FirstGenFreak
Thank you very much
22 hours ago, savePF said:
Thank you very much
Does The IAC operate only during the idle cycle or both idle and higher speed?
I suppose if it were stuck in the open or closed position from carbon build up it would effect it during either cycle.
So I have tried everything  that you all have been nice enough to take the time to suggest.
Dropping at the mechanic on Monday.
I will let you all know what he finds.
Thank you again
  • 4 weeks later...
So,
After all of the work and parts replacement, cleaning, diagnosing it turns out that my catalytic converter is bad!
It was blocking the exhaust which was the cause of all the symptoms .
Having it replaced.
The up side of all of this is that I really have learned a lot about my Pathfinder and had the opportunity to interact with and receive help from all of you folks.
It certainly won't be the last time you hear me chime in here.
Thank you
