Need advice on replacement
LazyAU
:welcome:
First two pictures look like the trans cooler lines are leaking. Might just be split at the ends. Should be easy enough to replace with bulk hose. Not entirely sure what's leaked on the rack, though again I'd check the lines and connections first. If it's too oily to tell where it's coming from, clean it as well as you can, drive it for a bit, and see what gets dirty first.
