k9sar Posted May 16, 2005 Share Posted May 16, 2005 95 SE. New problem started to occur. When I unlock my doors with my remote, the drivers side door lock peg does not come completely up. Though the door unlocks, it is obvious that soemthing did not work completely. I can easily pull the lock the rest of the way up. Problem is, if it's in it's half-assed position and I slam the door, it'll be enough to lock all the doors. I've read about the dreaded yellow thingie but is that only for the pre-90's pathys? Sound like the same thing? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 17, 2005 Share Posted May 17, 2005 Same thing. Either your lock actuator is getting weak on that side or the linkage needs attention. Open up your door panel and eyeball it to see. Link to comment Share on other sites More sharing options...
