Jacob824 Posted June 12, 2023 Share Posted June 12, 2023 (edited) Hi I'm new to this forum so I appreciate your patience with me. I am going to college soon and want to put some money in my 1997 se manual Nissan pathfinder with a 1/4 of a million miles. I don't want to lift it or change it too drastically. I'm going to do the obvious maintenance oil change, oil filter, fuel filter, spark plugs etc.. I also would like to do things that would improve my mpg like manual hubs. if you have any ideas to extend the life or mpg of my Nissan that would be appreciated. Thank you! Edited June 12, 2023 by Jacob824 misspelled college Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 12, 2023 Share Posted June 12, 2023 Maintenance is always a good idea. I did the transmission and transfer case fluids when I got mine (at similar mileage), and the junk that came out of the auto trans made me glad I did. If yours is manual, make sure you use GL-4 fluid, the more common GL-5 eats the synchros. I added a cooler and an external filter to the trans cooler plumbing while I was in there. If you replace the diff oil, and you've got the limited slip in the back, make sure you've got the limited slip additive to keep that alive. Power steering and brake fluid are usually neglected and nasty. Check the brakes. Have a look at the brake hoses, too, they may be in rough shape if they're original. Check that the front wheel bearings are tight, and the boots on the CVs and rack aren't blown out. Look for any obviously loose suspension/steering joints. Shoot some grease at any zerk fittings you find. Check for rust in the strut towers and fuel filler neck, or anywhere else you find it. Check the drive belts. Check the cooling system. If you don't know when the timing belt was done last, or it's been over 100k, do the timing belt. These are interference, so you don't want that to let go while the engine is running. While you're in there, do the idler, bypass hose, water pump, thermostat, and the cam/crank seals. There are instructions in the service manual, and in 5523's writeup, which has a less fussy way of setting the belt tension. Manual hubs should get you some mileage. Having it tuned up and running right will help too (plugs/wires/cap/rotor, air and fuel filters, maybe check the timing while you're in there). Make sure the MAF is good and clean, the vacuum lines are intact (including the one to the fuel pressure regulator at the back), the throttle body is reasonably clean, and the tube between the MAF and the throttle body isn't split. If you've got any OBDII codes, chase those down. 1 Link to comment Share on other sites More sharing options...
Jacob824 Posted June 12, 2023 Author Share Posted June 12, 2023 Thanks for the suggestions! I also was reading a another forum on npora and a guy said that a throttle body spacer could incresse mpg and a bunch of other things but reading further down the forum people seemed conflicted what is your guys take on it? this is the forum link Link to comment Share on other sites More sharing options...
Jacob824 Posted June 12, 2023 Author Share Posted June 12, 2023 10 hours ago, Jacob824 said: Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 13, 2023 Share Posted June 13, 2023 Link's not working on my end, guessing this one? I haven't tried it, but wouldn't expect it to do much. Carb spacers, sure, but all that's doing is adding a small amount of volume to the plenum. I wouldn't expect gains from the hot-air intake in that thread, either. Link to comment Share on other sites More sharing options...
Jacob824 Posted June 13, 2023 Author Share Posted June 13, 2023 okay thanks for the info! this is the forum link https://www.nissanpathfinders.net/forum/topic/32872-easy-mileageperformance-upgrades/ Link to comment Share on other sites More sharing options...
Aegloshen Posted May 2 Share Posted May 2 (edited) Learn With Cs-Cart Marketplace Academy is a fantastic platform for aspiring e-commerce professionals. Their expert-led courses provide practical insights into product management and digital marketing, empowering learners to excel in the online marketplace. As a dedicated student, I've benefited greatly from their interactive approach to learning. However, when it comes to seeking external assistance for academic tasks like dissertations, caution is advised. While services like https://essaypro.com/buy-dissertation offer convenience, prioritizing independent research and writing skills is crucial for academic integrity. Instead, consider utilizing university resources for personalized support tailored to your needs. Remember, the journey of learning is about both the destination and the process of growth along the way. Edited May 2 by Aegloshen Link to comment Share on other sites More sharing options...
