rraider1 Posted February 15, 2023 Share Posted February 15, 2023 Fixing sunroof leak 2003 pathfinder se looking for rubber strip than attaches to sunroof deflector 91280-5w500 that helps to deflect water to the channels that have drain lines. rubber was curled up at corners so water would run into other parts of sunroof channel Link to comment Share on other sites More sharing options...
adamzan Posted February 16, 2023 Share Posted February 16, 2023 Seems to be discontinued at Nissan. You might have some luck calling dealers to see if any of the warehouses have old stock leftover. Otherwise you'll have to go to a wrecking yard. Link to comment Share on other sites More sharing options...
rraider1 Posted February 16, 2023 Author Share Posted February 16, 2023 the sad part is I dont need the deflector i was hoping someone might have info on the rubber that is about 34 inches 1/4 in width in length it raps around the edge to help deflect the water. it is not shown on the parts diagram. checked with the local dealer they did not have any info on it. I will start to look at local wrecking yards but the weather strip may not be any better shape Link to comment Share on other sites More sharing options...
