Transmission issue
Hello I'm sorry for my lack of how to use this forum I'm still trying to figure it out.but my question is that I have a 95 Nissan Pathfinder XE four-wheel drive.all I need is the transmission.i was wondering if my tcase would bolt up to any other re4ro1a transmission that is compatible.any help is appreciated.thanks
It should since most of the difference is forward of the trans output shaft. It might be a bit of an issue if you also want to swap from a manual to an autobox because of the trans computer, but otherwise I see no real problems with another trans of the same model ( different vehicle, year, spec is okay... as long as it has the RE401 in the same configuration).
