Problems with O/D
christian
hey, just asking
i have a pathfinder 1995 it has an issue it dosent shift to O/D it was taken to a mechanic and it got the trans "fixed" , after that  it was working normaly around two weeks and the same thing started to happend again, we took it to an electromechanic and he said its a problem with the cluster, im looking for a second opinion or a tip from someone who had and solved this issue.
Thanks!
What did the first mechanic do? Make sure the overdrive off switch on the shifter isn't triggered accidentally (don't figure you would've missed that, it's got an idiot light, but worth checking before diving deeper). I very much doubt it's the cluster. Is it shifting normally between the other gears? And when you first turn the key on, before you start it, does the light in the E-AT switch flicker?
