Oil cooler O-ring(s)
BamaQX402
Just changed oil and found I have an oil cooler leak. Looking at them on eBay I see single as well as a 2pc set. Listed as;
21334-30F0A - Oil Cooler Seal
21304-JK20A - Oil Cooler Seal.
Do I need both, or just the JK20A?
Thank you! Getting a list of parts together, getting the P1140 code, so gonna replace both valves, plugs, injectors, and power valve screws while I'm in to it.
Anything else I should address or be aware of while the intake is off?
Thanks
  • 3 weeks later...
An update; I replaced both O-rings, however I probably could have just tightened the bolt. When I went to take it out, I thought my wrench slipped off the bolt because there was no resistance. So it wasn't even tight. No room for a torque wrench, but I did my best educated guess.
