SFD dimensions
johann_peralta
Hard to explain using words only, but here goes my attempt. If you were to stack the 2 face plates on top of each other (with the long end facing away from you). The slope would go from the long end of the bottom one to the bolt opposite of the long end of the top one.
Using that picture, the angle would go from the blue line of the bottom plate, to the hole touching the two red lines of the top plate. Using the picture, the strut spacer angles directly toward you.
