95 SE Rear Spring Leveling kit
Jimmie
fleurys , When installing your spacer do you leave the rubber spacer on the bottom and install your spacer on top of it? I have 31x10.50r15 tires that needs replacing and would like to go to 32x11.50r15 on the Lego rims. Do I need any lift for the 32's ?
The spacer goes at the bottom and sits directly on the steel support. Remove any rubber. You need a stable platform for the spacer
I cant help you for the tire question...i simply do not know. Sorry
