neilca Posted October 27, 2017 Share Posted October 27, 2017 Come to find out my left front spindle on my 99 4x4 has had a spun bearing. Any idea where I could find one? Link to comment Share on other sites More sharing options...
hawairish Posted October 28, 2017 Share Posted October 28, 2017 (edited) Not sure I follow. Do you mean one of the bearings locked up completely and spun the inner cone on the CV shaft? Don't think I've heard 'spun bearing' outside of crankshaft bearings, but that's a pretty different scenario. Edited October 28, 2017 by hawairish Link to comment Share on other sites More sharing options...
neilca Posted October 28, 2017 Author Share Posted October 28, 2017 Not sure I follow. Do you mean one of the bearings locked up completely and spun the inner cone on the CV shaft? Don't think I've heard 'spun bearing' outside of crankshaft bearings, but that's a pretty different scenario. Right! I replaced the bearings on this truck, the old ones looked OK but grease was black. I suspected they had never been changed in 150,000 miles. So all was good once I replaced and regreased the bearings, took it to be aligned and they said I had too much play in the bearing to align. So I take it apart, tighten the wheel bearing reassemble and find I still have play. I had tightened the bearing past where I thought it should be, lots of drag while turning, yet I still had play. I take the assembly apart to find the spindle had burn marks where the bearings ride. I slipped the inner bearing onto the spindle and sure enough there was my play. Not much but when you put a tire on it amplifies the movement. I have bought a used spindle from eBay. I an going to replace the inner bearing again. That should fix the problem. I have not seen this type failure in 30 years of working on cars. In the 1960's you would see it occasionally, but nothing recent. Link to comment Share on other sites More sharing options...
hawairish Posted October 28, 2017 Share Posted October 28, 2017 That's unfortunate and kind of surprising. Get any pics? Link to comment Share on other sites More sharing options...
