Just Finished 100k timing belt water pump.. BUT??
98Chilkoot
just replaced the timing belt, water pump, camshafts and crankshaft seals, new timing belt tensioner, and got all new belts. i'm sure the timing is correct, marked all the sprockets and counted teeth. I seem to hear a little sound that i never noticed befor, just can't tell what it is maybe just the new belts, or possibly i'm just really paraniod. if i would would have messed up with the timing would i really have noticed..... BABBABA-BANG?. everything looked pretty good but ovbiously i'm not over comfident in my work!
Hey, maybe you have a loose vacuum hose or plug wire still from the job?? are you leaking any antifreeze from the water pump? or maybe that missing wrench is rattling around under the timing belt cover.. :P
Edited by madhatter_xe
