91 pathfinder rear lift glass hinges
calvinM
Hi guys does anyone know where I can order new hinges for the rear lift glass.I think they were made of some plastic and on right side split open. looks like there was a roll pin across the inside of hinge.
Thanks
You might be able to get new ones from the dealer. Check factorynissanparts or courtesyparts to see what they want for them. Keep in mind there are two styles, one with the risers for the rear spoiler and one without, so make sure you're getting the right critter.
Personally I'd hit a wrecking yard or PM someone who's parting one out and pick up a used set.
Thank you very much for your help, Courtesy Nissan Parts had it for $44 RH side and they said it also fits "96" so I crossed it on ebay and found a good used pair for $45. thanks again. Courtesy looks like a good parts store ill keep it on my list.
Aloha Calvin m
