Crankshaft Nut
98Chilkoot
When I changed the timing belt on my Integra, I got a garage that broke loose the crank bolt using their impact wrench for $20. I drove short distance back home with not too tight crank bolt. For Pathfinder, I guess you will need to remove the radiator fan and the fan duct before visiting the garage.
Yeah, remove the starter and wedge a screwdriver into the flywheel. It even says so in my Chilton's manual. You could also use the old trick of feeding/stuffing a thin length of soft cloth in through a spark plug hole until it fills up the cylinder and prevents the engine from turning over, then pulling the cloth out.
I wouldnt recommecd this, but when i did mine I put a cheater bar on the wrench, then wedged it against bottom of the frame (unibody?). Then just bump the starter a couple of times. Came right loose.
Good luck
snosnk...
you're my kind of guy!! that is an ingenious way of loosening....but unfortunately my luck would break the starter!!
Way to go for the least erffort with the greatest output!!! :beer:
Edited by 98silverpathy
