jyeager Posted February 17, 2017 Share Posted February 17, 2017 I'm planning to install a light bar and a couple of work lights at the rear on the roof. Wondering how others have run the wiring? Thanks. Link to comment Share on other sites More sharing options...
fleurys Posted February 17, 2017 Share Posted February 17, 2017 For me , I used the A pillar for my roof lights. Everything fitted properly under the weather rubber strip... then the wires come out around the B pillar.. I put a small dab of black silicone and I never had any water come in between or under the weather strip.. here's a few pics.. 3 Link to comment Share on other sites More sharing options...
jyeager Posted February 17, 2017 Author Share Posted February 17, 2017 Thanks for posting up. I especially appreciate the pictures. My rear lights will be at the back corners of the roof, so I'm going to need to run the wire from back there. I was wondering if I should run them back above the head liner, or come forward behind the side trim panel(s). I will look in to running them up that channel for the roof rack, but I'm not sure that I want the headache that would create if/when adjusting my cross bars. And my light bar will have to be mounted to the roof at the front most portion just above the A pillars. I'm expecting to drill a hole and run the wires down under the A-pillar trim inside. Any advice? Link to comment Share on other sites More sharing options...
XPLORx4 Posted February 19, 2017 Share Posted February 19, 2017 I ran my wires up through the rear hatch and under the roof rack rail. I also ran wiring along my safari roof rack. See pics here: https://xplorx4.shutterfly.com/309 Link to comment Share on other sites More sharing options...
Pepo1 Posted August 13, 2024 Share Posted August 13, 2024 (edited) I ran the wires from the engine bay up the A pillar through some rubber floor conduit I found on Temu. It's self adhesive conduit stuck to the windshield surrounds on my Terrano. Will probably stick well to the glass itself. After a couple of months out in the weather, it is showing no signs of unsticking. I bought another length as backup in case it does eventually fail. See photos https://www.playbook.com/s/terrano/3TskQwfgDCu7Hbm5CNnk5ePz Temu conduit: https://www.temu.com/goods.html?goods_id=601099569483851 Edited August 13, 2024 by Pepo1 Correction 1 Link to comment Share on other sites More sharing options...
