Entropy98 Posted March 23, 2005 Share Posted March 23, 2005 Has anyone had any rubbing with 31's once they put OME suspention on. It seems that in a very tight turn to the left, while flexing slightly the tires rub a bit on the inner front side of the wheel well. I still have the stock wheels on. Would that cause them to rub because of the lack of backspacing? Link to comment Share on other sites More sharing options...
nick1716 Posted March 23, 2005 Share Posted March 23, 2005 my 31s rubbed just on the streets when i turned with 2 inch lift spacers... and i have 3.75 backspacing.. so not sure that the backspacing is the case. Link to comment Share on other sites More sharing options...
dwrounds Posted March 23, 2005 Share Posted March 23, 2005 Hey, I have bfg all terrain 31x10.50 on my 98 and I have just the slightest bit of rubbing on extreme turns. I have not experienced any rubbing while flexing. I am waiting on my camber adjust kit from AC and then I am going to put on my Old Man Emu springs. Any thoughts, suggestions, concerns? Have you had any problems? Danny Link to comment Share on other sites More sharing options...
Entropy98 Posted March 23, 2005 Author Share Posted March 23, 2005 Thanks I just wanted to know if it was normal. It was some extreem turns that it happened on, usually while turning left into a driveway. Link to comment Share on other sites More sharing options...
Trialsin26 Posted March 23, 2005 Share Posted March 23, 2005 dwrounds, camber kit? what for? I put the OME springs on it was only .07 out on the driver's side and .02 on the passenger side after alignment but still in factory spec. I rotate my tire every other oil change and the guy said I prob wouldn't see any tire wear untill after 20,000 mile or so. And he said that was a maybe. Anyway just woundering, I know Project Pathfinder used them. Link to comment Share on other sites More sharing options...
