Differential breathers
r50chilkoot
I am possibly looking to relocate my differential breathers into my engine bay, but I am not sure how to do it. If any one out here has done it, it would be much appreciated if you could tell me how you did it and if you were successful or not. If I do get around to doing it, I will post some pictures of it a possibly a step by step.
Haven't done it, but it wouldn't be difficult. Both diffs have a barb that you just need a hose to slip over (1/4"?) and then you just route the hose to your desired location. The front diff is already route to a point above the bellhousing, behind the engine. The rear diff just runs up to a chassis reinforcement, but would be easy to bring into the cabin.
Here's an existing project, which also re-routes the transmission and t-case breathers:
http://www.nissanpathfinders.net/forum/topic/33293-transmission-and-t-case-breathers/
That's helpful. I'll look into it. Thanks
