Everything posted by r50chilkoot
In case anyone is interested in how it went, I successfully swapped out the struts for stock ones using the lift springs. Works perfectly and I am quite happy with the results.
Ok. Good to know. I'll order up some new struts today then
So would you suggest buying a new strut assembly (or two) and putting in the larger spring that is currently on my current strut on the new one? This is what I have been considering as my main option, but I'm not 100% sure that is best as the suspension will be limited to how far it can travel. Thanks for the suggestion though. Ideally, I would like to avoid using coil spacers.
So recently my Pathfinder had been making some noise in the front right suspension, and I just found out today that is is being caused by a blown strut. Now of course my pathfinder has a suspension lift on it meaning that the strut is 2 inches bigger that stock. So my question for anyone who knows is, where can i get a replacement lifted strut? I am not sure if a lifted one from a newer pathfinder will fit. I'm also not sure if the strut is maybe out of a different model like a Xterra or something similar, or even if it is a factory strut with just a bigger spring?? Point being I don't really know what the strut is. All i know is that its 2 inches bigger than stock and that its blown. If anyone has any advice on how to fix this, it would be greatly appreciated. Thanks
Just as an update, I did tighten up the cables and there is no longer any slack in the pedal. Any pressure applied to the pedal now gives the engine throttle, as well I find that the cruise control actually is more responsive and accurate. Definetley would recommend tightening up these cables on your pathfinder if you haven't done it already
On my 1998 Pathfiner r50, I noticed that the throttle cable was loose and wanted to tighten it up, only problem is, there's another cable attached to the throttle body. I assume this cable is for the cruise control. I would like to tighten up both of these cables in order to achieve better pedal response, but I am unsure whether I will mess up the cruise control. So question being, am I able to tighten up both these cables and not mess up the cruise control in any way, or if I do this will my cruise control no longer work properly? The image included shows the cables I am referring to. Keep in mind, this is not my engine. Its an image I found online, but it is the same engine as mine and has the same throttle cable.
thats helpful. thanks
In my vehicle I have some mad belt squeak and its starting to get annoying. After a bit of research I determined that I don't have enough tension on the belts. Knowing this I looked under the hood and sure enough there pretty loose. I also noticed that there is not automatic belt tensioner's. So with this in mind, How can i adjust the tension on my belts? If anyone knows, that'd be helpful. Visual aids would also be helpful.
I checked it out. The trail does look really easy compared to some I've done, but it looks like it could be fun.
Sounds pretty good. Ill look through that and let you know how it goes when i do it here in the next couple of weeks
I am soon to be replacing inner and outer tie rods as well as ball joints on my pathfinder and am in need of some torque specs. I am unable to find them anywhere and was wondering if anyone knows them from experience, or knows a source where I could find them. Any information on the topic is helpful. Also, if anyone has any tips or tricks on doing this procedure, it would be helpful.
Thanks for the help. I'll look around.
I have a 1998 r50 and I am looking to upgrade the skid plate. The stock stock skid plate just isn't cutting it for me and I was wondering if anyone has gone so far as to replace it. If anyone has, do they know where I can buy one? If not has anyone made one before? And if they have, how'd you do it? The more information the better.
That's helpful. I'll look into it. Thanks
Just as a suggestion while draining any fluid in your vehicle, (this includes differentials, transfer cases, etc) always make sure that you can undo the fill plug first. If you undo the the drain plug and drain out all your oil and then go to fill it up, but can't undo the fill plug you're in trouble.
I am possibly looking to relocate my differential breathers into my engine bay, but I am not sure how to do it. If any one out here has done it, it would be much appreciated if you could tell me how you did it and if you were successful or not. If I do get around to doing it, I will post some pictures of it a possibly a step by step.
I'll have to do that. What I was thinking I would do is mount a plate on the inside of the fender that sticks out above the hood and slightly bend outwards and then another mounted to the door frame at the top of the window and then mount the limb riser cable to that.
I dont have any good pictures on my phone currently, but I'll show the one I have. For the install I had to make L brackets of of some scrape steel I had lying around and then welded that to a cross member that runs in behind the bumper. II then had to chop up the bumper a little bit to make room the actual light bar itself. Once I did all that i could drill holes in the l brackets and mount the lightbar to them. This works really well and looks really clean in my opinion. My only problem with it is it doesn't give much room for adjustment of the ligtbar after the fact. As well I find it is a little too low to the ground. It could be more effective it it were a little higher. Overall though I really like how its done. As well in the picture you can see some of the bumper that I had to trim to make it if fit. Would recommend doing this set up for sure though. And for anyone who wants to know it is a 24" light bar.
That's awesome that you guys are down to go, and gee, i wonder why they look sooooo similar @reeseb99
I am looking to put limb risers on my r50 pathfinder and was wondering if there is anyone out here who has done it? If there is do you have any sugestions on how to do it? Also I want to see what it looks like before I commit. Let me know if you guys have any information. This is the veichle I am looking to instal them on.
thats an awesome map!! And not too sure when I was planning on going, just kind of when I had time. Are you in the area?
A friend and myself are located in Cochrane Alberta Canada (near Calgary if you know where that is) and we're looking for another pathfinder enthusiast who wants to hit the trails. About 30mins from my house there is a really rad trail community and I would love to show someone around. If you're at all interested hit a reply!! I'm going to include a trail map of the area I intend to wheel. This is a image posted by the government of Alberta about trail closures that i took earlier. Its the best complete map I could find.
wired up a lightbar in my bumper and redid the wiring for my cb radio
