m_lars Posted November 27, 2016 Share Posted November 27, 2016 So the XJ guys do it all the time, mine were gone, so why not try it? I used 12' of 4x3 11ga steel that ran me $60 cash and a few rattle cans of "corrosion resistant" rubberized undercoating. Cut out was really easy because the bottom at the pinch seam was literally 90% gone, the top seemed more solid but that turned out to be not all that true. We had to notch out the tubing in 2 spots where there were structural components. One was at the front of the front door, the other was at the pillar between the doors. There was another brace that appeared to give lateral stiffness to the rocker area, I cut that one out since the box steel has way more strength than the rocker ever had. After the cutting was done we jacked it into place with a slight downward angle and welded the top in place. It was rough welding because the steel was so thin in places. You'd start getting a nice bead and it would blow through. With the top done the pinch seam extended about a 1/2" past the steel, so we hammered it around the bottom of the steel and welded away. I then taped off the door jambs and gave it a couple coats of undercoating. I still have the passenger side to do so I'll try to get some pics of the process. But in the mean time here are a couple of the finished project. It's still a rusty, ugly beast but it's my rusty ugly beast. Probably the best $250 vehicle I've bought. 3 Link to comment Share on other sites More sharing options...
NismoChris Posted November 28, 2016 Share Posted November 28, 2016 (edited) Legit Edited November 28, 2016 by NismoChris Link to comment Share on other sites More sharing options...
ChemExposure Posted November 28, 2016 Share Posted November 28, 2016 Nice, If I ever decide to get rid of my diamond plate running board I might do this but they do make accessing the roof rack extremely easy so I'm on edge about removing them entirely. Do you figure there's a way to mount the tube rocker plates as well as a running board? Link to comment Share on other sites More sharing options...
bushnut Posted November 28, 2016 Share Posted November 28, 2016 nice, I've been thinking of doing this for a while. did you tie it in to the main "frame rail" at all with gussets or something? Link to comment Share on other sites More sharing options...
jyeager Posted November 29, 2016 Share Posted November 29, 2016 Rocker repair and Rock sliders in one. Good! I'm very impressed you could do it without blowing through the rotted rocker everywhere and creating a big useless mess. Link to comment Share on other sites More sharing options...
m_lars Posted February 22, 2017 Author Share Posted February 22, 2017 nice, I've been thinking of doing this for a while. did you tie it in to the main "frame rail" at all with gussets or something? No, it's just welded to the top of the old rocker in the door jamb and the pinch seam on the bottom. Given how heavy the steel tube is I'm not sure you could hit it hard enough to need a tie in. Rocker repair and Rock sliders in one. Good! I'm very impressed you could do it without blowing through the rotted rocker everywhere and creating a big useless mess. That was definitely the tricky part of this project! You'd be welding along just fine and boom it'd blow through. Link to comment Share on other sites More sharing options...
ChemExposure Posted July 6, 2017 Share Posted July 6, 2017 Have you got around to the passenger side yet? I'm hoping to do mine in September before another winter season. Link to comment Share on other sites More sharing options...
