gamellott Posted November 19, 2016 Share Posted November 19, 2016 Good Afternoon!!! Yes, I'm new here and I've been brainstorming on how to give my 92 Pathy some more power without putting in a turbo or dropping a SB V8 into it. Is this frankensteined engine something that Actually can be done using existing hardware?? I've done a little research and discovered that the heads won't bolt up to my Factory VG30E. I've read in one place that this is feasible. Will the VG33 block bolt up to the factory MT and what parts do you need to frankenstein from a donor vehicle? I understand that I will be looking at donor vehicles of a 300Z for the intake and heads and some kind of Frontier/pathfinder for the block. OR... If all else fails and the Frankensteined engine isn't an option, will the VG30DE bolt up to the MT? Thoughts, Experience??? Thanks Geoff Link to comment Share on other sites More sharing options...
LittleFR Posted November 20, 2016 Share Posted November 20, 2016 Welcome. Maybe you can post a question in your year model forum and get help from folks knowledgeable in your model. I've seen threads on many engine swaps, even LS and 4.3 Vortec swaps and tons of info on interchangeable trans units. Slow down, use the search and good luck. Frank Link to comment Share on other sites More sharing options...
Vern_K Posted November 23, 2016 Share Posted November 23, 2016 finding info on VGs can be kind of a pain at time so I will help you a bit early VG30E= A-B block also includes the VG30i which is the single injector throttle body. W block VG30E is from 86-87 on, not sure of the switch date. mixing and matching A-B block and W block heads can be done with a little extra work but some combos don't work. the VG30E is found every where all the blocks were made with mounting bosses for both FWD and RWD so a Maxima engine will go into a pathfinder by switching the mounts and such..... VG30DE= no use and trying to put the head on a VG30E block, to much work switching timing belt stuff just use the whole engine VE30DE= 92-94 Maxima SE only engine, based on a VG block with DE timing chain heads, it is kinda a baby step between the VG motor and the VQ VG33E= late VG motor lots of info on here about them..... those engines will bolt to your transmission without a adapter, oil pans and pumps and such might could be a issue with some of them.... 1 Link to comment Share on other sites More sharing options...
gamellott Posted November 23, 2016 Author Share Posted November 23, 2016 This is the kind of information I've been looking for. I'm more partial to the DE engine because it has a shim and bucket type valve train in addition to the boost in HP without any kind of turbo. I noted that the blocks are different between the DE and E engines because they have completely different head gaskets which is what clued me into there actually being a difference. None of this is going to happen tomorrow, so I'll start looking for a DE engine or a good donor vehicle eventually... Or maybe I'll just find a nice 300z that someone is willing to let go cheap. Link to comment Share on other sites More sharing options...
Kingman Posted November 26, 2016 Share Posted November 26, 2016 (edited) A/B-Series is from '84-'3/87. W-Series engines are from '4/87 on. A/B vs. W has nothing to do with injection type. '86+ blocks all interchange since that's when they started building the (W)D21s. You can swap an earlier one but you have to modify the motor mounts to match the block bosses. And yeah, the single cam and dual cam motors don't interchange heads. They do cranks and pumps and stuff like that with some work. Edited November 26, 2016 by Kingman 1 Link to comment Share on other sites More sharing options...
gamellott Posted November 26, 2016 Author Share Posted November 26, 2016 Thanks. I appreciate the info. Link to comment Share on other sites More sharing options...
Vern_K Posted November 29, 2016 Share Posted November 29, 2016 A/B-Series is from '84-'3/87. W-Series engines are from '4/87 on. A/B vs. W has nothing to do with injection type. '86+ blocks all interchange since that's when they started building the (W)D21s. You can swap an earlier one but you have to modify the motor mounts to match the block bosses. And yeah, the single cam and dual cam motors don't interchange heads. They do cranks and pumps and stuff like that with some work. ok yea thats right the only things that came with a A/B were Maxima's and 300 and the first year of VG30i, I also don't remember what VG30E have the long crank snout been a while since I was looking into such things. I think I have been cramming to much VQ engine info into the engine file..... 1 Link to comment Share on other sites More sharing options...
