bump stops
headpeace
hey I jusdt checked my bumpstops, if I recall correctly there should be about 3" between each bump stop and its respective bumper (for lack of better term), is that right, also is that while jacked up? cuz on the ground I got an inch both ways
measured with the pathy on the ground there is only 1" on the UCA, my concern is if that is supposed to be actually about 3" then if I start crankin the t bar then I'll get only 1 inch and be on the bump stop, does that make since?
i dont know where you got the 3 inch idea.
1 inch is fine, even as low as 1/2" is ok.
that 1/2" will give you over an inch of lift most likely.
good luck.
also after you reindex the T bars bounce the front end and take it for a spin around the block, then check again, sometimes it will changs a little.
