seafoam in pcv valve
Guest punkrawker
Guest punkrawker
so i tried seafoam and not impressed, i put some in the pcv intake and now there seems to be an air bubble in the engine, a slight sputter/ split second stall or hesitation randomly and seems to be more frequently around 50-60 kmh. any thoughts?
I've used seafoam in numerous vehicles, I tend to under shoot measurements out of being cautious. Only use the brake booster line in order to do the intake, YouTube can help if you don't know what you are doing. If it's just a sputter, it could be numerous things. Just check your plugs, replace PCB valve etc. You didn't hydro lock it it doesn't seem.
Sent from my XT1585 using Tapatalk
