Speedo off
I have an 88 SE V6 w/ manual tranny that was supposedly recently rebuilt. Since ive had it the speedo is 7-8 mph off ex: speedo says 65 my gps speed says 57-58. I'm thinking the tranny rebuild may have some thing to do with it. Also the tranny is hard to go into 1st and 2nd gear when you first start it up. Any thoughts on both?
Sent from my XT1585 using Tapatalk
Speedo gear could be the wrong one. Are you sure the transmission is filled up properly with the correct oil? If it was rebuilt properly you wouldn't have shifting issues.
Sent from my SAMSUNG-SM-N920A using Tapatalk
An SE comes with 31/10.50/15.
The difference in circumference between a 31 and a 29 Inch tire is approx 6% or 5-6 mph.
Your indicating a 7-8 mph difference. The added 2 mph variance may be dependent on the accuracy of your GPS and speedo.
My info plate n the driver door says 235-75-15 (tire size on it now) which is why I didn't consider that as a factor. I'm pretty sure the guy I bought it from botched up the tranny rebuild and has something to do with it.
Not sure what the logic is as to how the transmission changes the speedo reading. As far as I know, the speedo gear (in the 88 Pathfinder) is in the t-case. Even if the gears in the transmission are somehow affected/changed during your repair, its the t-case output shaft that registers the output shaft rotation to determine speed.
Was the t-case taken apart during the repair? Or is this in the original t-case that came with the Pathfinder, or is it a swapped t-case that perhaps came with a speedo gear for 31" tires?
I was thinking along the lines the previous owner swapped the transmission and t case as a unit with another since it's easier to do than splitting.
Reason I said I thought tranny rebuild may have something to do with it is I got the feeling from talking to the guy I bought it from and looking under truck it wasn't the best job. But as far as I know he didn't mess with the transfer case. As far as changing the gear that regulates speed is it easy to get to? I'm guessing you buy diff one for diff size tires?
Hope this helps
AT and MT 31s
32703-31G18 18 teeth (BLUE)
AT small tires
32703-31G20 20 teeth (RED)
MT 4wd
32702-33G17 17 teeth 31s
AT and MT small tires
32702-33G19 19 teeth (unknown)
