Tanderson2503 Posted April 18, 2016 Share Posted April 18, 2016 I love my first Nissan Pathfinder it has a cool interior and a responsive engine! However, the front left power window stopped functioning ! At first it seemed that the window/ motor were slipping but as it happens, I can operate the switch and I can hear the motor but there is no movement of the window ! I would greatly appreciate any advice or suggestions on the proper repair! Thank you! Link to comment Share on other sites More sharing options...
RF600 Posted April 18, 2016 Share Posted April 18, 2016 My first thought is, if you can hear the motor but nothing is happening, regulator. But, can you manually, by hand, pull the window up? I put my window down the other day. It went down and I continued to hear the motor. Once I took it apart the cables for the regulator weren't broken. My first thought was the regulator, so I ordered one before taking it apart. Turns out the motor was toast. I ended up replacing the motor and regulator. Both needed replacing. I have a 95. So I don't know if the motor and regulator are sold together or separately compared to a 96. Link to comment Share on other sites More sharing options...
Tanderson2503 Posted April 18, 2016 Author Share Posted April 18, 2016 I do not know! I do know that with the assist of the motor and pushing upward from inside the door I was able to raise the window to the closed position but it does not stay there! Link to comment Share on other sites More sharing options...
RF600 Posted April 19, 2016 Share Posted April 19, 2016 Pull it apart to see. That's the only way to know for sure. Link to comment Share on other sites More sharing options...
Tanderson2503 Posted April 19, 2016 Author Share Posted April 19, 2016 Yeah, I figured it was all coming down to that, no matter what! Thanks for the feedback. I appreciate it! Link to comment Share on other sites More sharing options...
RIPB.88 Posted April 19, 2016 Share Posted April 19, 2016 Its your Window Regulator. Easy replace. Working in a glass shop, I see that all the time. Link to comment Share on other sites More sharing options...
