transmission or power steering leak.
David4x4
I have a 04 pathfinder and just discover it started leaking by the pnp switch. I check the turbine sensor area and it seem dry. I also see a few hose but they seem dry also. Its only that turbine revolution wire.
Question is does that sensor have a hose inside that wire cover dressing.im full on atf fluid also. Any help is greatly appreciated.
20160229_171053_zpsg5komsnv.jpg[/ur
Edited by David4x4
