canucklehead Posted March 7, 2005 Share Posted March 7, 2005 I started the day with intentions of changing out the shocks on my 95. I've had these Rancho 5000's in my garage for about a half a year or so. I presoaked the bolts on the truck with penetrating oil. Proceeded to take off top nut. Seized. Got the grinder out and ground her off. Started taking off bottom bolt. Took a bit to crack it and felt a little stiff when I cranked it. Took a closer look and realized that the bolt was not actually moving, but in fact had bent the support with the nut on it. Realizing this I tried to turn the bolt back in but it wouldn't go. So I took a chance knowing that I might break something and continued. Dang it! I snapped the nut off of the support. So now I have the bolt stuck through the supports and the shock and I am at a loss. I tried to hammer it out. Tried with a bigger hammer even. Still won't budge. It's almost like it is twisted into the rubber bushing or something. I thought about melting the bushing with a torch but seeing as they are gas filled shocks, I didn't think that would go well. Any ideas out there? Link to comment Share on other sites More sharing options...
Airrun2002 Posted March 7, 2005 Share Posted March 7, 2005 Should have got ahold of an impact wrench thats what i used on my 95 and it worked like a dream. but im not sure what to tell you... take some pics that might give us somemore ideas. Link to comment Share on other sites More sharing options...
statikuz Posted March 7, 2005 Share Posted March 7, 2005 I don't think they're flammable-gas filled shocks. But yeah, take a picture or two and maybe we can see what you're talking about. Link to comment Share on other sites More sharing options...
94extreme Posted March 7, 2005 Share Posted March 7, 2005 not sure if i am reading you right but if i am then vice grips on the nut and a wrench on the bolt... otherwise burn away... Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 7, 2005 Share Posted March 7, 2005 Dammn, man. Is it just me that's never had any problems removing nuts and bolts on my Pathy? That's just nuts. Link to comment Share on other sites More sharing options...
94extreme Posted March 7, 2005 Share Posted March 7, 2005 must be... but i am guessing you've turned all nuts and bolts on you tk at least a couple of times by now... Link to comment Share on other sites More sharing options...
jj big shoe Posted March 7, 2005 Share Posted March 7, 2005 (edited) That's the good thing about my oil leaks...it keeps all the bolts lubed. Edited March 7, 2005 by jj big shoe Link to comment Share on other sites More sharing options...
