Break lights not working?
jamesondexter
I have a 92 pathfinder that will not light up the break light when you press on the pedal. I have tried everything I can think of. I have changed bulb, cleaned out the little connector and even tried to trace the wires back as far as I can. I could only go so far because the little cover in the baa pretty small. Any ideas and maybe solutions would be great thanks!
But you have running lights? No running lights would be a larger problem I think. I know there is a switch under the brake pedal but I thought its "fail mode" was to light up the brake lights. Maybe you want to check that the switch has all of its wires attached? I don't know what to suggest after that though.
Check fuses in the dash panel I believe it's a 10a fuse. My front park lamps went out and this also wad affecting the brake lamps. Discovered it was a 10a on the bottom row. 4th one across from the right labelled STOP LAMP.
