jamesondexter
Everything posted by jamesondexter
  1. I have a 92 pathfinder that will not light up the break light when you press on the pedal. I have tried everything I can think of. I have changed bulb, cleaned out the little connector and even tried to trace the wires back as far as I can. I could only go so far because the little cover in the baa pretty small. Any ideas and maybe solutions would be great thanks!
  2. Well a body lift will "lift the body" where a suspension lift kind of dose two things. It can allow you to gain ground clearance and how far your truck can flex. Suspension is good if your looking for ground clearance. A body lift is good but it separates the body from the frame and can lead to needing different parts to make it so you can shift or stop and sometimes it can even screw up how your truck rides. This is a good place to get a lift http://www.jcwhitney.com/lift-kits/nissan-pathfinder/c11313d1685j1s21.jcwx. Hope this helps.
