amfq120 Posted November 20, 2015 Share Posted November 20, 2015 So my Pathfinder had a little bit of a stutter occasionally when I press the gas more than half throttle. I pulled the distributor out to try to turn it one tooth hoping that the timing was just off a little, but now it won't start. I smell a little bit of hot electrical smell. Any advice on what I'm doing wrong or what I need to do to get it running? I've tried turning the key just a little bit until the timing marks are visible on the crank pulley Link to comment Share on other sites More sharing options...
amfq120 Posted November 20, 2015 Author Share Posted November 20, 2015 I've tried turning the key a little until the timing marks are aligned roughly, and then inserted the distributor with the rotor pointed towards the number one cylinder, but it still won't start. Link to comment Share on other sites More sharing options...
RF600 Posted November 21, 2015 Share Posted November 21, 2015 You have to make sure #1 is on TDC. Then stab the distributer. Then get a timing light and time it. You are probably 180 out. Link to comment Share on other sites More sharing options...
amfq120 Posted November 21, 2015 Author Share Posted November 21, 2015 I'm following the Haynes manual to the best of my ability. from what I can tell the number 1 cylinder is the front left one, I follow that wire to the distributor cap and then point the rotor at that while the crank pulley is on the second Tic which should be TTC Link to comment Share on other sites More sharing options...
Kingman Posted November 21, 2015 Share Posted November 21, 2015 Front right is No.1 (passenger side). Make sure it's on the compression stroke, and try stabbing it with the rotor one tooth before the No.1 terminal in the cap. Link to comment Share on other sites More sharing options...
amfq120 Posted November 22, 2015 Author Share Posted November 22, 2015 That's where I have it set, would it still not start even if it was close? I've been smelling hot electrical from somewhere between the battery and firewall, it's not the fuses there, they don't smell or look burnt. I also heard a rapid clicking noise coming from right behind the engine above the trans...starting to think I may have blown something somehow. Link to comment Share on other sites More sharing options...
amfq120 Posted November 23, 2015 Author Share Posted November 23, 2015 Got it running, it was 180 off Link to comment Share on other sites More sharing options...
RF600 Posted November 25, 2015 Share Posted November 25, 2015 Good to hear you got it figured out. Link to comment Share on other sites More sharing options...
amfq120 Posted November 25, 2015 Author Share Posted November 25, 2015 Thanks for the info Link to comment Share on other sites More sharing options...
