4x4 hubs
lalinde89
Hello guys!
Im having a problem with my left hub, when i lock them and put the 4H, I start to hear some little click and if I put the 4L I hear a louder clac sometimes.
Maybe you could help me to find an answer, thxs!!
Enviado desde mi HUAWEI G7-L03 mediante Tapatalk
Manual hubs or auto? And does the hub lock up properly when it's doing this? You can get the auto hubs to bang a little if you're spinning the rear end when they engage, but it's not really a click. I haven't found the manual hubs to make any noise, though you might check and make sure the bolts haven't backed out or something.
Honestly your issue sounds more like a CV going bad.
I assuming auto hubs. Before I scrapped mine they would occasionally thunk into place. If it is the hub I say go to manual hubs, a world of difference.
If its a manual hub it may be loose or going bad. Id pull them and check.
While you are there check your CVs!
