AC lift question
nick1716
I only did the rear myself, so I can't speak for the front.
Make sure you get a large enough coil spring compressor. The one I borrowed from Autozone was not made to work with coil springs that were as wide as the Pathfinder ones. It's pretty easy with the right compressor. Some of them are made to work with any diameter spring, others will only work with certain diameter springs. The tool I got the second time did the compressing all from the outside of the spring and was very easy to use.
well i got the front on pretty easy..didnt have time for the back since pep boys took 4 hours to do the stupid struts! but ill get it done tomorrow and have some pics with the lift and 32 inch mud terrains
