joluma09 Posted August 28, 2015 Share Posted August 28, 2015 I have a possibility of buying a 92 pathfinder that caught on fire for $400. the whole .ca is in good shape but obviously engine is toast. so my question is a the 4x4 setup a straight bolt on to a 95? Link to comment Share on other sites More sharing options...
joluma09 Posted August 29, 2015 Author Share Posted August 29, 2015 anyone? Link to comment Share on other sites More sharing options...
djratlif Posted August 29, 2015 Share Posted August 29, 2015 Wish I could help man, not my department on that one. Seems like they would be a "quick and easy" swap, but I am not sure of the difference in crossmembers, oil pans, or torsion bar setup. Seems like the 2wd has a tension rod up on the front of the control arm where as the 4wd has a strut rod to the rear? I'm only going from memory here but I know my 2wd Frontier was staying that way for a reason, and I think its because it was not a quick and easy thing like I wanted. This is all speculation on my part, I'm going off the newer WD/D22 chassis vs the older WD/D21. Link to comment Share on other sites More sharing options...
hawairish Posted August 30, 2015 Share Posted August 30, 2015 Wish I could help man, not my department on that one. Seems like they would be a "quick and easy" swap, but I am not sure of the difference in crossmembers, oil pans, or torsion bar setup. Seems like the 2wd has a tension rod up on the front of the control arm where as the 4wd has a strut rod to the rear? I'm only going from memory here but I know my 2wd Frontier was staying that way for a reason, and I think its because it was not a quick and easy thing like I wanted. This is all speculation on my part, I'm going off the newer WD/D22 chassis vs the older WD/D21. I'm not sure that was the case on the WD21, but I know what you're talking about on the Frontiers. I have a 98 2wd also...completely different frame from the 4wd. I was under the impression that the WD21s had the same frames. Someone else will need to confirm that, of course. Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 31, 2015 Share Posted August 31, 2015 I would venture to guess that you can swap the drive trains with minimal issues. There was a post, a complete write up iirc on here but searching via tapatalk is not working and I am away from a usable computer... Link to comment Share on other sites More sharing options...
joluma09 Posted August 31, 2015 Author Share Posted August 31, 2015 ill keep looking around. hopefully it doesn't sell by the time i find or get info. link of said car since it will be a partout after i get the 4x4 stuff. http://tucson.craigslist.org/pts/5177823545.html Link to comment Share on other sites More sharing options...
