djeffrey Posted May 13, 2015 Share Posted May 13, 2015 Hello, I am going to have a new exhaust made up, my stock exhaust is tired and muffler has a grapefruit sized hole in it, I am wanting to go up in size to 2-2.25 all the way back. I already have pacesetter headers installed. Where I have it register smog checks are not required so I don't have to worry about that. Do you all think It would be beneficial to remove the cat? Or would it cause too much of a loss in back pressure? What muffler would you all suggest? From all the reading I have been doing a flow master 40 seemed like a good choice. I don't want it to be crazy loud, just sound good and wrap up nice when I Rev it out. I have also installed a vg33 if that makes a difference. Link to comment Share on other sites More sharing options...
Precise1 Posted May 13, 2015 Share Posted May 13, 2015 Removing the cat won't give you much more power, and might make you lose some low end torque. It is also illegal and might make your Pathy worth less/harder to sell down the line. My recommendation is that you have a Magnaflow 'high flow' cat installed; 2" is the largest legally for California (unless something has changed) and is what I have. I'm certain that it is not restrictive... My set up is a stock VG30E with Thorley headers, 2" Magnaflow cat, 2.25" piping (more than enough) into a Flowmaster Delta 60. Sounds good without being too loud but is raspy at higher RPM, I think there is something not secured properly. One more thing I have to do... B Link to comment Share on other sites More sharing options...
