fearkobe Posted April 25, 2015 Share Posted April 25, 2015 are these a common problem? this one is im assuming on the exuast pipe on the passenger side. Link to comment Share on other sites More sharing options...
Precise1 Posted April 25, 2015 Share Posted April 25, 2015 Well, you have 4, pre and post cat on both sides. No it isn't normal for them to come loose, the standard complaint is that they are a pain to remove... B Link to comment Share on other sites More sharing options...
fearkobe Posted April 26, 2015 Author Share Posted April 26, 2015 I believe it's on the exhaust pipe so is that the pre cat? Thanks for the reply Link to comment Share on other sites More sharing options...
Precise1 Posted April 27, 2015 Share Posted April 27, 2015 The pre-cat are in the rear of the exhaust manifolds, you can see them under the hood near the firewall, and the post-cat ones are under the car before the two pipes merge. I do not recall the exact placement, but they should be easy to spot. How do you know it is loose without knowing where it is? B 1 Link to comment Share on other sites More sharing options...
