Front Wheel bearing, too tight?
ferrariowner123
So I just did a bearing and brake job on my 96, and I just went through the drive through and heard what sounds like a dog toy squeak coming from the wheel I changed the bearing on. Is it possible I put them on too tight?
I followed the FSM on bearing tension, but had to turn the bearing nut forward (clockwise) so the lock collar could line up so I put the screws on to lock the nut in place. I'm fairly sure it's the bearing since it's speed dependant, and it doesn't change when I apply the brakes...
What do you guys think?
-Kyle
Jack it up, do the axial play test, then do the preload test as well. You can do this using gravity and weights if you don't have a spring gauge. ;)
I'm going to assume you packed the bearings properly...
Check the caliper bolts, slide pins as well. Did you lube them?
Alright. I'll look up to do those. Atleast the second one. Lol
I just did a simple hand pack, pushing the grease from the bottom (wide part of taper) till it started oozing out the top. That's what I have seen done on roadkill (when it wasn't called roadkill).
I'll try and find some time this weekend to look at it and hopefully it's a simple thing, I just heard it again against a low wall, but now it's a lower speeds, like 5 mph and lower.
Thanks for the help and suggestions!
-Kyle
Edited by ferrariowner123
