2 plugs/harnesses hanging below fuse box?
echoentertain
I can't answer that question. What I can say about connectors that are not used. Most manufactures make 1 harness for their vehicles. It's easier to make 1 rather than multiple harnesses. If you look around the vehicle you will find multiple connectors not used.
I know that doesn't answer your question. I wasn't sure if you were aware.
if one of the plugs is under the steering wheel it may be for the under dash/foot well light that some trucks have, the diagnostic connector, in the area mentioned usually has a clearish rubber boot over it and is rectangle.
