ebayfish Posted November 23, 2014 Share Posted November 23, 2014 Since I've put my taller/heavier tires, my pathy stops fine, but doesn't stop quickly enough in a panicked situation. Are there any brands or materials of pads that seem to do the best for our trucks? I don't really want to change calipers out, upgraded rotors would be an option if not overly expensive too. I gave drum rears. Link to comment Share on other sites More sharing options...
daczone Posted November 24, 2014 Share Posted November 24, 2014 sounds like fade, drilled vented rotors would probably help. I put a some on my Ford at all 4 corners when I did a lift and bigger tires and it seemed to help. I also went with the ceramic pads. (my ford had 4 wheel disc brakes). Link to comment Share on other sites More sharing options...
adamzan Posted November 24, 2014 Share Posted November 24, 2014 Semi metallic seem to work the best for me. I have rear disc though. Maybe try some hawk hps pads? I hear they're great. Link to comment Share on other sites More sharing options...
daczone Posted November 25, 2014 Share Posted November 25, 2014 Did my brakes yesterday and by far the EASIEST brake job I have ever done! Rear disc's didn't require any turning the pistons to get them to retract they just went right back in with a C-Clamp. Dual piston front calipers was a nice surprise. Link to comment Share on other sites More sharing options...
