98 pathy build thread, right
PINION
The turkey baster is for removing all of the old fluid from the resivior.
slave cyl is 14mm bolts, line at slave is 13mm banjo, line to line is 10mm, and bleeder is 8mm
if your bleeding the system, be sure the hose is submerged in fluid or the bleeder is closed when you let off the pedal, could have back sucked a little air. and leave a little fluid in the res so you dont suck air from the top side. Im sure you know that, looks like you do good work bud.
Pat
Edited by fixinto
