pathykline92 Posted September 15, 2014 Share Posted September 15, 2014 I'm getting ready to rebuild my original engine. I found a groove In the rear seal area possibly from the seal lip. Is there a sleeve kit available? Any recommendations on an overhaul kit. Also a question about the lower Crankshaft timing belt gear removal. Thanks for your help. Link to comment Share on other sites More sharing options...
Nefarious Posted September 15, 2014 Share Posted September 15, 2014 There is actually a sleeve for the crank to give a new sealing surface. I'm not sure but I think rock auto carried it? Link to comment Share on other sites More sharing options...
Precise1 Posted September 15, 2014 Share Posted September 15, 2014 Is the groove deep enough that a new seal won't fill it? You are ging to have to search here for the rebuild kit, I know it has been discussed, but I don't recall the info. What is the question about the crank timing gear removal? How to? It is just a tight fit with a shim washer before or behind it. It can corrode in place under some conditions and sometimes the clocking key way is compromised so the key may be binding it. IIRC, you can't really get a grabber behind it for a puller or slide hammer so I would recommend looking down the keyway in the gear to see what you can (maybe striking it the opposite direction with a hammer/drift if you see it is binding) and/or soaking it with a penetrant and giving it some deadblow love after a couple of days. Back and forth radially until you get some movement. I believe prying is ill advised... B Link to comment Share on other sites More sharing options...
Nefarious Posted September 15, 2014 Share Posted September 15, 2014 I wouldn't pry on the crank gear either. I've pulled one quite a few times and just a little wiggle and persuasion by hand was always enough to break it loose. I've also used a soft rubber mallet to tap gently on the edge of the gear just to break any corrosion bond loose as I work it forward with my hand. Never had any issues doing that Link to comment Share on other sites More sharing options...
k9sar Posted September 15, 2014 Share Posted September 15, 2014 I used repair sleeves on my camshafts. I would recommend it for the crank as well. Gives a nice smooth surface for the new seal but makes it a little more difficult to get the seal on. Link to comment Share on other sites More sharing options...
pathykline92 Posted September 15, 2014 Author Share Posted September 15, 2014 Thanks for your help especially with the crankgear, I'll start soaking it with penitrating oil when I get Home Link to comment Share on other sites More sharing options...
Manik Posted September 18, 2014 Share Posted September 18, 2014 I'm getting ready to rebuild my original engine. I found a groove In the rear seal area possibly from the seal lip. Is there a sleeve kit available? Any recommendations on an overhaul kit. Also a question about the lower Crankshaft timing belt gear removal. Thanks for your help. I had an issue getting my crank gear off at on point, it was seized to the crank. I wound up drilling a 1/4 inch hole just above the keyway slot and with a little persuasion with a hammer and chisel got it off without damaging the crank. Not really recommended, but, had no choice at the time. Try a 50/50 mix of acetone and ATF, it works better than PB Blaster or WD-40 as a penetrating oil. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Kingman Posted September 19, 2014 Share Posted September 19, 2014 Had to destroy mine to get it off. Sometimes they rust on there and it won't easily come off. Not often but it happens. Link to comment Share on other sites More sharing options...
