nick1716 Posted February 12, 2005 Share Posted February 12, 2005 when you get your car aligned after its been lifted do they fix the camber angle? Link to comment Share on other sites More sharing options...
Trialsin26 Posted February 12, 2005 Share Posted February 12, 2005 From what I was told if you get the OME springs that have a 3/4 to 1 inch lift in the front you shouldn't have to worry about the camber, but I could be wrong, but then again I'll find out as soon as I finish the front end. Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 13, 2005 Share Posted February 13, 2005 A proper alignment will fix caster, camber and toe measurements. Link to comment Share on other sites More sharing options...
Trialsin26 Posted February 13, 2005 Share Posted February 13, 2005 Let me restate that. You won’t have to worry about a camber kit. But as 88 stated you will have to get a proper alignment. The general rules I go by even before a lift is every other oil change rotate and balance your tires, and every 4th oil change get an alignment. Link to comment Share on other sites More sharing options...
nick1716 Posted February 13, 2005 Author Share Posted February 13, 2005 thanks 88..and trailsin it sounds like you take really good care of you rig...i only get my tires balanced once and rotate em about every...actually i have never rotated them..i havent had a set of tires for more than 5k miles haha i keep goin bigger! Link to comment Share on other sites More sharing options...
